Car Dolly
captainron
Reel 'em in
Anyone know how to make a solid car dolly with casters, to support a TR shell after a frame drop? What would be the best mounting points on the body?
R
this is mine...
Used a set of wheel dollies, 4 jackstands, and some angle irons.
I welded the jackstands to the dollies and the angle to the the jackstands then bolted the angle irons to the front and rear mount locations. Works like a charm and was cheap and affordable!
no problem
glad I could help - i was just trying to use some things I had available - ive attached a couple more pics that are a little bit more clear on how i did it, these were on my comp at work - its a bit hard to tell but on the back i had to weld to additional angle irons to the top of the jackstand and then used wood blocks as spacers ( needed a bit more height ) and shot a bolt through the angle and wood spacer into the body mount
