Blackonblack89
- Apr 12, 2011
Car runs decent untill you give it full throttle then breaks up cuts out won't run at all, boost gauge shows 3lbs never moves even when key is on it shows 3lbs, I found vacuum line that runs to map sensor it was run from map to fuel regulator, no vacuum hooked n anywhere so I teed it into back of intake runs ok, egr hooked up car won't run at all take vacuum line of egr and seems to run better could this be my full throttle problem?
