OK, I have a new engine and it ran fine on Saturday of the BMC for 5 runs. Late sat it started to miss. It will not drive,brake tourque, or rev up in RPMs without a stutter. That night i swapped out wires, Ing Mod and Coil pack with known good without any help. I changed spark plugs twice( I did not know RS43s were not to be used in GN1s) with race Autolites and Autolite 103s . I swapped the ECM, and Chips (several times). Also swapped MAF, with a traslator setup, still no good. I did have an exhaust leak from the drivers side gasket plus four ckackes in the header. I had them welded and put a new gasket on. Yester day I changed the injectors and it still stutters. The fuel pressure is fine and never drops off under load. I did a compression check at the BMC 150 on the Drivers and 160 on the Pass side. I am lost now. i need your infinate wisdom here. Today waiting to let it go closed loop it tripped a 45 code rich exhaust O2 voltage and cross counts were fine. I would like to make it to the dyno session on SAT at ATR. Any ideas?
Thanks,
MJH
Thanks,
MJH
