can't set the boost the way I like
an87ttype
I would like to set the boost so it spools up fast but doesn't over boost. I've tryed without the MMbst command and with and just can't get it quite right.
With the boost command I can set it so it spools good but the minimum setting is like 18psi. Knock city on pump gas! If I loosen the rod just 1 turn the minimum is 14psi (no knock) but the spool up sucks. Its worse without the controller.
Any ideas? different boost control maybe?
Thanks all!.............
