Dave Dunbar
- Sep 10, 2012
On the ignition module, pin F, gray red wire. Power feed to crank sensor.
Question is this wire should have 12 volts on it right?
KOEO this wire has no voltage. Running it has around 4-6 volts. Unplugging the sensor has no effect. The wires are
sound between the two, the module is receiving the right voltage and its grounds are good.
The car runs well but has a miss at low rpms. I'd describe it as a rhythmic shake.
Is my module bad?
I would like to watch the crank signal but I don't have a scope.
Is my module bad?
