350turboGN
- May 15, 2013
I'm asking because I would like to keep my stock GN wheels an I would like to upgrade my rear drums to disc
I'm looking at either ls1 camaro breaks or blazer brakesThe best answer is maybe. What brake upgrade are you looking at getting?
Lol I'm sorry my stupid phone! What's the spacing on the turbine wheels? I know it's just the inner edge that I'm worried aboutI know the F body rears will fit a factory aluminum turbine style wheel but not sure if they'll fit a steel wheel. And the word is brakes, btw.
Alright thanks for the info with all these questions I'm new to BuicksI used a set of the Western 8.5" wide with a 3 & 5/8" back spacing to check, but the rotors pushed the wheels so far out they wouldn't clear the rear fenders.If they were 4" back spacing they would've worked. They should fit the stock turbines though.
Ya I heard that the 15x7 Monte wheels fit I'm from pittsburgh where are you fromfind someone with a 98-02 F body with rear discs to see if you can try your wheels on their car.. where are you located: i've got the LS1 disc brakes on my 86 Camaro front and rear, so if you're close enough you could stop by and see if they will fit on either end..
for the record, 15X7 aluminum Monte Carlo SS wheels fit over the LS1 brakes front and rear, with about 1/4" of spacing at the closest point on the rears and a slight interference with the caliper fins on the front that i took care of by just dusting off the tips of the fins with a flap wheel on an angle grinder..
Alright what size wheel does your car have?my location is in my sig: Howard Lake, MN... the board used to show your location if you wanted it to, but it doesn't any more..
Alright I have gta wheels up in my roof of my shop I just put GNs on itcurrently, it's got 4 16X8 GTA "rear" wheels on it, but the aluminum 15X7 Monte SS wheels also fit.. i don't know of anyone with a GN in my area so i can't try one of those wheels over my brakes..
Maybe, back off the bong, a bit??Ya I heard that the 15x7 Monte wheels fit I'm from pittsburgh where are you from
Lol!Maybe, back off the bong, a bit??
