When going down the street, if I let off the gas the rpms drop to 500rpm and the car sometimes dies. When it doesn't die the engine acts like it catches itself and jumps back up. But the car dies frequently. I did get a code 45 once (the o2 sensor is almost new), and the idle is rough.
I can't find any vacuum leaks.
I changed chips from extender + with 3" MAF sensor to Joe Lubrant and stock MAF, and it still does it. I've adjusted the IAC to the normal parameters (10-20 in park), I've adjusted the TPS sensor to .44 at idle and 4.5+ at WOT.
How do I know what happens when an ECM goes bad?
How do I know what happens when the IAC motor goes bad?
Can anyone help please!
Ken
Ken
