On a sequential system I am wondering what is happening when I disconnect the cam sync connection on the distributor, fire up the car and drive around like normal. How can the engine fire if the sync is disconnected. Just wondering if somehow the computer assumes a postion for number one and considers that good enough? Basically the car seems to run just the same as before.
Wondering then if when the cam sync is connected if the computer just sees where number one is and after that never uses that signal until the next start cycle?
