Hey guys,
OK, so I am going to put in an X3 cam from Full Throttle.
Specs are: in-218@.05 w/.460 lift
ex-222@.05 w/.479 lift has 112 ls and installs @110.
It is hyd. flat tappet, I have ported stock heads and 1.55 roller rockers
So my ?'s are what springs, lifters and rod length do you recommend? Would stock spec be ok for all? The springs are what concern me the most. Also, should the cam be degreed either direction or straight up?
Thanks so much,
Lee
Thanks so much,
Lee
