K KIDDBOOST New Member Joined Nov 6, 2002 Aug 4, 2003 #1 the little tab on the interrupter ring keeps breaking off. this has happened numerous times and need help solving problem.
R re-evaluating Can't even re-member Joined Jun 5, 2001 Aug 4, 2003 #2 get a hold of Bill Get a hold of Bill Anderson he can weld it for you.. 410-282-9335
E EightSecV6 MDBL Joined Jul 18, 2001 Aug 5, 2003 #3 We can repair it so it wont ever break again!!!!!! We would need the sensor, the front cover, oil pump gears and oil pump cover. Thanks, Bill
K KIDDBOOST New Member Joined Nov 6, 2002 Aug 5, 2003 #4 Is this a common problem? If so, what is the cause/causes? I seem to be the only one in our gang that is having this issue. What is the cost of the repair and expected turn-around time for the work? Thanks for the help.
