When I first took my cam sensor out, I marked TDC with a sharpie on the top of the cam sensor (the part that spins to the stationary part on the sensor. I also marked the bolt where the sensor mounts). Now putting it back in as Im putting the engine together, I can't get the top of the cam sensor perfectly allinged. I put a new timing chain and sprockets in, so I was thinking that the tension of the tight new sprocket and chain may have effected the cam sensor to not line up perfectly again. The top of the sensor is maybe 1/8" off from a perfect allignment tha I had before I took the sensor off at TDC. So I think I may need to time this differently or something. Is that amount off very crucial? Weigh in on the situation if you have advice.
Thanks.
Thanks.
