buickpower
polytetrafluoroethylene
- Jun 27, 2003
I was reading an article on gnttype that said sometimes sputtering or popping with larger cams can be helped by advancing the cam sensor a couple of degrees. It also listed the lengths of tape you put on the balancer to get varying degrees of timing. Since default is 25 deg ATDC, would 24 degrees be advancing the cam sensor? Just wanted to verify.
