I did some major engine mods and am now trying to get cam position sensor set. I did the TDC and then 25 degrees ATDC and set the CPS with a Caspers CPS tool. Engine won't start. The one thing I didn't do is make sure that the #1 cylinder was on compression and not exhaust. Can't I now simply change the CPS window 180 degrees and then I should be good assuming all else is right? Is this logical or not? And how to I change the CPS 180 degrees? Do I pull it and change the shaft and window position 180 and put the cap back in the same place or do I just loosen the hold down bolt and rotate the cap 180 degrees? Any help would be appreciated. Thanx
