I have a roller cam I would like to know it's spec's
It is a 3.8 cam
Original markings 819506 and 97D
Now Dremel marked C3105,C3105, HR107,E7219
I called Comp a while back and they thought it might be equal to 201/201
Comp cam High Energy lobe3105 = 256 duration 200@ .050 lobe lift .310 .480 with 1.55 rocker (stock) found in comp cams lobe book page 18
I would say the HR is Hydraulic roller LS 107
E7219 I think is the customer ID#
It would work good , often we use more cam than we really need. It looks more like a stock grind slow valve speed should be vary quiet and easy on valve training
Most cams for our cars have fast ramp speeds and high lift this cams lobe looks to be on the conservative side.
I have my own theory about the idle upper end noise. These Buick make 10-20 lb oil pressure at idle along with high spring pressure on the valves. I thing it a case of high bleeding on the lifters.
Ever owned a set of Rhoads lifters ?
