"C-Com WP" 3D chart not showing proper live cursor position
Supercharged408
When I am connected to the ECU and running, my 3D tables are not showing the proper location with the floating cursor. When I am idleing around 620RPM (yes, the dash displays proper RPM) the floating cursor is only at about 380RPM. As I raise RPMs, the cursor continues to lag behind a few hundred RPM. Even when I press the spacebar to go to the "active cell", the result goes to where the floating cursor is (which is not in the correct postion). I have tried restarting the program, even rebooted the system, anyone have any ideas?
oh, and I am running version 1.003, how do I get version 1.005???
Damon
I have had the same problem with the 1.005 and still waiting for Craig to answer
Propably its a windows problem so uninstall the fast and install it again
This will cure the thang for a while
Same thing here.. I changed the dashboard guage to use the 'scaled rpm' and it set everything straight. I just assumed with the adjusted throttle blade position for the IAC that caused it to read differently.. or for whatever reason. Supposed to or not, the table appeared right with the different guage.
