FastRegalWE2
Wish I had another Buick!
- Jan 10, 2004
These are most of the parts I was going to keep for my next GN but I dont think Im going to go as far with the next one as I did with the last one...
1 50lb injector.....$25 (only have 1)
2 83 lb injectors $30 each (have 2)
5" Monster tach with shift light, Sport Comp $125
2 5/8" ELECTRIC Fuel pressure gauge with sensor and wiring $150 (was over $200 new) Sport Comp (mounted in radio surround trim with delete plate)
2 5/8" EGT with pyrometer, probe and wiring $125 Pro Comp (mounted in radio surround trim with delete plate)
2" Electric trans temp with all hardware, NEW never installed $30 Sport Comp
3" Electric Water temp with all hardware $20 Sport Comp
Cometic HG's NEW $150
Hood shocks cylinders (Kirbans) $25 for the pair
ATR driveshaft loop $50
Chrome A/C Compressor cover (BuickGN.com) $20
Manual boost controll, locking style with under dash panel and vac lines $25
stock battery hold down $10
stock 200R4 detent $20
TPS tap harness for powering FAST system (Caspers) $30
2 gauge console gauge holder, grey, $15
2 pod a-pillar gauge holder grey $20
stock coil bracket $25
stock 3 leg alt bracket $25
Serial to USB adapter cable for FAST $10
push in vavle cover breather $5
rear upper axle housing bushings, black urethane NEW $15
stock fuel return line bolts to timing cover, I had the rubber removed and repalced with braided stainless, nice piece.... $40
Power Master mini starter $150, I installed it to adjust the spacing but never fired the motor with it (was about $200)
-8 AN fuel feed line, enough to run from the tank to the fuel rail with high pressure high flow anodized mesh filter (filter alone was almost $100) Worked fine on my car with 554RWHP -$75
stock injector harness $35
All parts are off and ready, pics upon request
Or will trade entire lot for a nice low mile 87 GN.... j/k :tongue:
