turbo3.8monza
- Oct 24, 2006
I'm selling a factory 4.1l alum. four barrel intake manifold with quadrajet , cast iron water neck (no thermostat), and egr block off plate. The intake has been sandblasted and clear coated and has been port match felpro MS96033PB gaskets and the plenum has been ported so that you could and edelbrock carb. (it has to be an edelbrock and you have to use the inner set of holes) without an adapter plate, and has studs for a edelbrock, so you will have to get longer ones for the front of the quadrajet. The carb is a rebuilt stock quadrajet with the choke mechanism and the vaccum module for the secondaries (for neck snapping secondaries like a double pumper holley).
It is listed on ebay listing number 160179846762
