For the best spool-up from stop, where did you guys set the TPS values? I got mine at about 3.0 volts or so, not too impressed. As far as the 3rd gear setting, I left it at factory setting (on controller). I am assuming if I turn the screw clockwise, then boost in third will increase, and counter clockwise will lower boost in third? I am not seeing much difference at all as far as quicker spool up. I guess I will keep playing with it. ALSO, not using aftermarket boost gage right yet, going by the factory one (inaccurate at best).
