P powerwagon05 Member Joined Aug 8, 2008 Jun 29, 2009 #1 went to take out iac pulled wire off whole thing broke off in my hand like it had been cracked and just hanging on:frown: anybody have an idea how to get this out, plunger rod in the way for an easy out thanks for any help Attachments broke 002.jpg 62.7 KB · Views: 117
C chrisgarrett Registered Member Joined Jun 2, 2004 Jun 29, 2009 #2 There are four Philips screws that hold the IAC housing to the throttlebody. Try and offset screwdriver.
T Turbo T-type Member Joined Jun 4, 2006 Jun 29, 2009 #3 The same thing happened to me. I was able to jam a rather large flat bladed screw driver in the middle and unscrew it that way.
P powerwagon05 Member Joined Aug 8, 2008 Jun 29, 2009 #5 powerwagon05 said: thanks for the info ill give it a shot!! Click to expand... got it out and new one in car running good thanks agian:biggrin:
8 8UWITH6 Keepin' The Shiny Side Up Joined Dec 30, 2001 Jun 29, 2009 #6 Wow, how'd you pull that one off, ahaha
P powerwagon05 Member Joined Aug 8, 2008 Jun 29, 2009 #7 8UWITH6 said: Wow, how'd you pull that one off, ahaha Click to expand... jammed a chisel into opening then used a cresent wrench on chisel to back broken piece out, turned out to be pretty simple with help fro above posts
