Dr. Jeckel
- Jul 29, 2003
Well I just got through spending the better part of three days changing my timing chain, water pump, adding an external oil cooler and swapping out valve springs on the car. Not to mention cleaning all the gunk off everything.
Good news was that the old cam gear was in perfect order.
Bad news is that after getting everything on and back together, I go to fire it up and it just cranks over. I thought the cam sensor was outta wack so I take the top off and start moving the balancer and the reluctor didn't move. I thought that can't be good so I pull it out and look inside the front cover and my brand new timing chain is broke. I thought I was about to have a breakdown.
What could have caused it to break? The heads and cam are stock and I put on comp valve springs. The timing chain and gears were replacement "cloyes" pieces from O'Reillys. It was REAL tight when I put it on, it took a little bit of effore to get it all on there.
My question is has anyone else had problems with these replacement chains and did I bend any valves when I was cranking it over? When I cranked the engine over it didn't sound like I hit any valves, my friend bent some on his Ls1 during a cam swap so I know what it sounds like.
Should I get another set from O'Reillys and see if it fits looser or get a replacement peice from Aggressive or some vendor?
I would like and need to get this done as soon as possible, but don't want one to break again or while I'm doing 100mph. Please, any help or advice is GREATLY appreciated.
Thanks, James.
Thanks, James.
