I broke my drive shaft in 4th gear doing over 130 - I put everything back together and now there are no gear changes, feels like it's stuck in low. Shifting through the gears manually does nothing.
Yes. Remove the pan and look towards the rear of the trans. There will be an aluminum housing retained by four, 13-mm bolts. Remove that and the governor will slide out for inspection/repair.
