Breathers for M&A Valve Covers
first ya gotta get the gaskets (mr gasket)... just make sure you trim the inside flaps or you will be blowing oil all over everything....the K&N breathers fit fine
Thanks AZGN, but which K&N's? The same one used for the stock valvecover/turbo inlet?
those will work...you can get bigger, fancier ones, but i like the little ones....just make sure those gaskets don't overlap
Connelys was the best price I found and they had them readily available. They are the mini K&N that is also used on the passenger side of the stock VC's. I think the price was around $13 each.
HTH
Thanks guys.
AZGN, what gaskets are you talking about not overlapping? The gaskets for the breathers to fit in or the gaskets for the valve covers. I have the "centerbolt" types with the o-ring gaskets.
the breather gaskets...they have overlapping pieces of rubber in 'em that will seal together under boost.....ya gotta trim 'em so they don't seal (unless you like fogging for mosquitos...)
