T Texas gn Member Joined Jan 14, 2011 Nov 28, 2012 #1 Quick question, Will I need to bleed the brakes after removing the brake switch on my powermaster? Kinda looks like mine is acting up.
Z zeus87gn Automotive Neurosurgeon Joined Oct 14, 2005 Nov 29, 2012 #2 Short answer - no You may want to cycle the accumulator a few times to get any possible trapped air out the switch in on the high pressure side
T Texas gn Member Joined Jan 14, 2011 Nov 29, 2012 #3 zeus87gn said: Short answer - no You may want to cycle the accumulator a few times to get any possible trapped air out the switch in on the high pressure side Click to expand... Thank you for the info....As soon as i get the part i will get it installed! Thanks again.
turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Nov 29, 2012 #4 Make sure and discharge accum before removing switch.....
