This is probably an easy one for those well versed in brake systems.
Had to remove the dash panel from my column shift TR, so had to put the car in drive to pull it off. After fixing my problem, cycled into drive again, and heard air coming from the rear of the car when I depressed the brake. Brake light came on (obviously). Got out and looked, to find two puddles --- one larger on the pass side of the rear end, and a smaller one on the driver's side.
What needs to be replaced? Is it the rubber hose section? I'd like to figure this out and have parts before I take it in to be fixed.
TIA, jn.
TIA, jn.
