I'm working on a buddy's GN...
I just connected a Casper's VSS signal conversion module to send VSS signal to ECM and a tach module to run the cruise control.
Electrically, that end of things seems fine. The Scanmaster is showing accurate and stable MPH, but the speedometer is bouncing up and down.
This is a VDO electrical speedometer, not cable-driven mechanical.
I already lubed the upper speedo cable, but not the lower yet.
Is it possible for a sticky cable to make the speedo jump, but yet the scanmaster and ECM see stable MPH ??? That's what confuses me... If the cable is making the speedo bouncy, why not the ECM signal too ???
