boost? on jay carter 93 octane
87gnstock
Bigger isn't better!
How much boost can i safely run on the jay carter 93 octane chip. I am running 10 right now just ot be on the safe side. I don't want to blow a head gasket so i need to keep the boost at a safe level.
I could run anywhere from 15-17 with good results on regular 93. Didn't have another chip at the time so when I put some 100 in the tank, I could crank the boost up to about 21 and do pretty well.
Depending on your car, the quality of gas you have available to you, the air and the position of the north star in relation to your turbo, you should be able to run anywhere from 16-18 PSI.
