I put an adjustable WG on and the boost will only rise to 19psi. Im running a Thrasher 100 with K\N and Hooker with no cat. Have walbro 340 with afpr. with the stock WG it would run up to 17psi and settle back down to 16. With the adjustable I was able to turn it up to go 19psi with it dropping back down to 18 at WOT. I have tuned the rod 5 more turns with no effect. The car runs fine and pulls well but the boost just won't go up any further. This is a stock turbo with 90k. The only odd # on scanmaster is that the MAF will still not peg even at 19psi, it tops out at 227. Is the turbo just tired or am I overlooking something? Thanks for any help you guys can give. Tom
