Hey guys,got a few questions.My buddies t type has an issue with boost drop off a little after 1-2 shift,and even more after 2-3 shift!i told him that he must have a boost leak some where.His boost is set at 20lbs and the turbo is a 60.He also has a rich idle,and it seems to hunt for idle a little.TPS, and IAC were all reset as was idle rpm using procedure in the factory shop manual,and everything looks good,but it seems to idle low in park(700-750) and is rough.O2 looks good,the car also has a reds 93 chip!Thanks!
