Hello, finally got the car running well enough to make some WOT runs. As far as I can tell all is stock with the exception of the fpr and the chip but can't tell who's chip it is. Boost stays at 14lbs until she winds up in 3rd. Slowly rises to 16lbs at which point I get out of the throttle, don't want to break anything. Replaced all the vacuum lines, check valves, boost lines, and tested actuator, no leaks. Is this normal for a stock set up? Could the boost solenoid be bad, is there a way to test it? Don't have a scanmaster yet but hopefully soon. Thanks, paul
