boost control question
DOUBAD RACIN1
I have a 85 hot air, 86-87 ecu,
60lbs injectors, ta33 turbo,
Direct scan, and msd boost controler..
My question is..
My msd boost control has a plug for a map, with that being said do i just plug my map in it and delete the map Wiring from the stock wiring harness...
My question is..
My msd boost control has a plug for a map, with that being said do i just plug my maf in it and delete the map Wiring from the stock wiring harness...
No why would you remove the MAF because it's asking for a MAP signal. Just splice into your map sensor and run it to the controller .
