Need to help diagnosing another issue with this car. I'll give as much info as possible. I haven't driven this car much since I bought it back in late February. Have maybe 200 miles max on her since purchase. Only had the pedal to the floor a couple times for very short durations. The car is a beast and I didnt want to break anything or shit myself. After a short burst with my wife in the car the water temp jumped to 210 in a hurry. I was real close to home and parked it. Found I had a big coolant leak from what I thought was the water pump. Got it taken apart to replace and found it was just the upper radiator hose that rubbed through on the water pump pully. Replaced the pump and hose anyway since I had one and everything was apart. Start it up and its running like crap. Was running a little rough earlier too. I'll post SM readings below. Put everything back together fire her up, let her idle. 1250 to start, drops to 850-900 after warm up. After warmup temp shoots to 200. I'm getting lots o bubbles in the overflow, and some black smoke out the back pipes. Its the HG right? The car needs a tune for sure. Heads are O-ringed GN1's from Weber. Rest of the set up is in my sig.
SM readings at idle warm(may be in improper order)
TPS .44
IAC 95
MAL 23 code - maf?
AF 10
INT 114-122
BL 128
CLT 143-159ish
ATS 71
I was writing these down fast before shut off. may be missing a reading.
Thanks for any help
Neil
TPS .44
IAC 95
MAL 23 code - maf?
AF 10
INT 114-122
BL 128
CLT 143-159ish
ATS 71
Thanks for any help
Neil
