Braxton Jordt
- Mar 18, 2013
So I have a scanmaster and when my car is warmed up I checked the numbers and I get 160 for the blms and 00 for Iac. What does this mean?
ive checked for vacuum leaks and cant find anything. is this just at an idle that its dumping a ton of fuel or at wot also. would swapping my pvc to an rjc one be a wise decision?
This is how I use it.close all the valves on the engine as to not let air out.now u can put the leak tester @the turbo an build pressure from there or as I do it,take the up pipe off an place the leak tester on the throttle body.now with the valves closed an the leaktester on give it no more psi then the max boost u run on your car.so if you run 15psi of boost then give nomore then that on the tester.now that the intake is charged with air now get a soapy water bottle an spray you will be amazed on what u find.So how do you use this type of leak tester?
Braxton Jordt said:how do I close the valves?
87-WE2 said:There may be another way (not sure), but if you remove the vc's and take off the rockers, all cables SHOULD be closed.
The car runs great when I floor the car the 02 milivolts are about 900 so I didnt know if the blm and a vac leak had to do witht that or not
