Matt McClung
Hotair guy who owns a I/C
- Sep 18, 2001
Well, I thought that maybe the stock bottom end would hold up until winter, but apparently not. Was driving and went to pass a vehicle and stood on it and poof, all the sudden a dead cylinder and lots of smoke. Smoke is being pushed out of the breather, so along with a dead miss, I assume a piston went or rings. I have put TA performance headers on it, a RJC 3 inch downpipe, Precision 64-66 turbo, 60 lb injectors, extender chip, and Alky kit. Been running very good, but I knew with all the extra power I was on borrowed time with the bottom end. Well, I planned on this winter to put a stroker crank, rods, forged pistons, roller cam, Better cylinder heads. I already took the engine and trans out today and also plan on going from my 2800 stall to a 3200 stall converter. I will freshen up the transmission as well, it is a fifteen year old Art Carr transmission that is still going good, but figure I would at least check on the clutches while it is out. Any ideas on what I should do? I don't know if using a stroker is a good idea or not, but I need to get this done quick. I still have plenty of summer left to go and have plans with the car. Advise on good components and build ideas are appreciated. I just plan to mostly drive the car on the street and go to shows, but may go to drag racing events once in a while.
Thank you
Matt
Thank you
Matt
