Jeff Moore
- Apr 26, 2007
[Does someone out there have a procedure to bleed a Powermaster]
I hope this is the only problem ..I have!
Anyway this week ..I just installed a used PM ..(seller says it was good)
..I have brakes..However the Press Sw keeps klicking on-off..(I did change
Sws..but still klicks) also the PM motor runs longer than it should..
The brake pedal ..initially is good > however ...if you hold the pedal
down (long enough) it will go to the floor..
there is no fluid leaks..
Any Ideas.. not bleed completely ...? thanks!
