A MFS (billet) 67 mm with a stage 5 or clipped p trim turbine or the old standby cast 67 will get it done. Your 10" converter will not be able to couple the power very well once the engine is making enough steam to run 10's. Low 10 sec power will show extremely high slip and e.t. and mph will be limited. The engine will be out of the power band out the back because of the slip. A 9.5" PTC will be requried.Bison what turbo could you build me for mid low tens? I'm gonna order 80# injectors tt 6.1 chip and Alky. Don't wanna change torque convertors I have ptc 10" 3200 stall non lock up
87_we4 said:Will a 6262 do the trick? Car is a weekend street car with a few drag trips a year
87_we4 said:How much for Bb 6262? I just pulled the specs up for the pt51 and measured the wheels and that's what it is
