BIGGEST PARTS LIST EVER, also parting 2 GN's and a Limited
Intercooled88s
Moderator
New Parts added to list
87 Engine 69k $2000
87 Engine 46k $2400
BRF tranny $500
8.5 Posi rear complete drum to drum with driveshaft $750
8.5 rearend housing for GN $300
Stearing column from 87 GN 46k in very good condition, even cruise lever chrome is nice $150
Dash Pad(grey) in very nice condition $100
87 GN seats front and rear in nice condition $450
Upper door chrome trime strips for GN $30 each in good condition
87 GN engine harness $200
Adj fuel reg $60
Power Master 69k $200
87 Power seat track $85
Lock set (3 locks) $60
86-87 tranny dip stick tube $40
Locking T-tops $150
T-top boot shaped plates that the t-tops lay on $60
GN console $150
Dash harness $70
GN Concert sound 2 lower door panels $120
GN passenger seat in good condition $80
87 Grey passenger seat in good condition $80
Tail lights $110 a set
Quarter glass $100 a set
power trunk mechinism $20
Trunk Lid blackout trim piece $35
Blue console lid $30
New T-type emblems $20 each
Tri shield GN horn center $50 no ring
T-type horn center $30 no ring
T horn center $30 no ring
Front air dam(both sides) $40
T-type header panel $150
85 Turbo to intake adaptor $40
ENGINE PARTS:
AC compressor(84-85 AC compressor) $40
AC compressor(86-87 AC compressor) $60
AC lines(86-87 or 84-85) $45
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(Oil cooler adaptor with nut) $30
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $30
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $70
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover) $20
Belt tensioner(86-87) $70
Block(109 Block) $300
Cam position sensor just the lower part(no cap) $30
Cam position (sensor with cap) $65
Chip(stock 86 chip) $30
Chip(stock 84 chip) $20
Coil pack(84-85) $40
Coil pack(86-87) $40
Control module(84-85) $50
Control module(86-87) $60
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
CONVERSION (84/85(Hot Air) to 86/87(Intercooled) conversion parts(all the original GN parts you need to convert
over from 85
to 87) $1400)
Crankshaft(Turbo crank will need to be turned to .010/.010) $250
Crankshaft(Turbo crank .020/.020, never run in engine) $150
Crossover pipe(84-85 Exhaust crossover pipe) $35
Dip stick and tube(86-87 dipstick and tube) $40
Dip stick and tube(84-85 dipstick and tube) $30
ECM(85-85 ECM) $40
ECM(86-87 ECM) $70
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $45
Headers(factory Exhaust headers,both sides)$100
Heads(stock 8445 heads needing rebuild) $40 a set
Injector harness(84-85) $35
Injector harness(86-87) $40
Intake manifold(86-87 Lower intake manifold)$130
Intake manifold(86-87 Upper intake manifold)$30
Intake manifold(84-85 GN intake) $40
Intercooler $60
Intercooler brackets both for $50
Intercooler fan $40
MAF(86-87 MAF) $80
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Motor mounts(Engine frame mounts) $35
Oil pan(Turbo oil pan) $35 each
Power steering pump(86-87) $60
Pulleys(86-87 underdrive pulleys(crank and alt)) $35
Pulley(86-87 Crank pulley with adapter) $30
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$15
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttlebody(86-87 Throttlebody with TPS,IAC motor,vacuum manifold) $60
Throttle bracket(86-87 Throttle bracket) $35
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(86-87 Throttle cable) $30
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Turbo(86-87 Turbo can be used as a core) $50
Valve covers (84-85) $30
Valve covers (86-87) $35
Valve cover oil filler tube(86-87 tube and cap) $30
Wire harness(84-85 engine wire harness) $100
Wire harness(86-87 engine wire harness) $200
INTERIOR:
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Console(85-87 GN) $140
Console(grey and shifter on the floor)$100
Console shifter plate(Plate on console that goes around the shifter)$30
Console(half console for Limited)(grey and shifter on column)$100
Dash pad no cracks(grey or Maroon) $100
Dash pad(Maroon dash pad, no cracks) $100
Door panels(87 T-type upper door panels) $60
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Gauge cluster(Analog) $50
Light sage green seat belt guides $25 for both
Light sage green seat belt upper bolt cover, triangular shaped trim piece $20 for both
Map light $20
Radio(Stock GN radio, no EQ) $50
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hradtop car $40 for both
Seats(87 GN seats front and rear in great condition) $500
Seats(87 GN Front bucket seats need recovering) $150
Seat belt set(grey)(10 pieces) $60
Shifter $35(84-87 GN, needs T handle)
Steering column(grey and shifter on the floor)$120
Steering column(grey and shifter on the Column) $100
Steering wheel (Grey and in excellent condition(not redyed or recovered) with horn ring) $300
Steering wheel(good to have recovered) $40
Surround(Gauge surround) $35
Surround(radio surround) $25
Third brake light(Grey, red Maroon, or blue Third brake light)$25 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, or grey , all 6 pieces $100
Visor(Nice blue passenger visor with lighted mirror) $25
Body Parts:
Blackout door handles $15 for both
Blackout wheel well trim $40 each
Blackout(Front windshield blackout trim(3) )$40
Blackout(rear window blackout trim(3) )$30
Bumper(GN Rear black bumper) $100
Bumper reinforcement(Alum. Front bumper reinforcement)$100
Bumper reinforcement(Alum. rear bumper reinforcement) $80
Grill (86 T-type grill) $70
Grill(85 GN grill) $60
Grill (87 chrome grill painted black) $40
Grill Emblem(85-87 T-type grill emblem) $20
Grill emblem(87 , says "Buick") $20
Fenders(84-87 GN fenders(GM)) $80 each
Header Panel(84-87 T-type header panel) $150
Lock set(all 3 locks with key) $60
Quarter windows with blackout trim $100 for both sides
Tail lights with blackout trim $100
Tail lights with chrome trim $70
T-tops(86-87 GN locking T-tops) $150 a set
T-tops(84-85 GN NON Key locking T-tops) $150 a set
T-top black trim that the t-tops rest on(sort of L or boot shaped) $50
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror)$20
Mirror(Passenger remote mirror) $40
Windshield blackout trim(3) $40
Windshield chrome trim(3) $30
Wheel wells(Turbo plastic wheel wells) $80 each
Any other blackout piece e mail me I have them all
Hood(GN hood) $95-$150
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Misc:
Antenna( black manual antenna complete with mast, base and nut)$35
Antenna base nut and spacer for Power antenna with black trim $10
Driveshaft for 8.5 rearend $50
Fuel pump hanger/sender $50
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $100
Hydrobooster brakes $100
PowerMaster to firewall adaptor(bracket) $30
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
Transmission(BQ coded GN transmission 48k) $300
Transmission(BRF coded tranny) $500
Tranny cooler $20
Transmission oil pan(Stock 200 4r tranny pan) $25
Transmission(BRF tranny , missing valvebody and oil pan) $100
windshield wiper assembly $15
Wheels(86-87 T-type wheels for all 4 in good condition)$250 or 1 For $90
Wheels(86-87 GN wheels)good for cores all 4 for $100
E mail me at Fortune628@aol.com or Bobhebert574@aol.com
My phone # is 413 746 9668 I rarely check my voice mail so if you call and don't get me try again later. E mail is quickest to contact me.
What kind of shape is the GN hood in? Also the rear bumper. Please shoot me a price on each shipped to 79106.
Thanks! :D
I am very interested in the complete 8.5 rear and drive shaft. Do you know what shipping would be to Florida 32542 ?
Brian
INTERCOOLED
Hood is in good condition its not perfect, needs paint. Rear bumper is in good condition. I can send pictures , whats a good e mail address to send you pictures.
85monte
Im not sure the exact shipping I will have to call the Freight company , there office is closed until Monday, it should be around $200 , maybe a little more or less.
9daysbefore
The regulator is on a car I bought dont know the true mileage of the regulator or the brand, it looks like a accufab, but Im not positive. I can send pictures on Monday.
upper door panel trim and sail panels for a GN hardtop
Do you have the trim that runs all the way across the GN upper door panels at the pull straps? If so... is it real nice? I am considering sending my uppers to Jax.... to have them re-covered.... but my trim looks crappy.....looks like someone keyed it.......Send pics of that if you have it... and pics of those hardtop GN sail panels please.
bdykes@beabulldog.com
Interested in 8445 heads providing they're not cracked. Let me know how much for shipping to 32940 (Fl.) Thank You
Blazer406
I'll send pictures of the best upper door panel chrome strips I have and the hard top sail panels , wont be until tomorrow.
First in line if you have the stainless rear wheel well trim from the Limited.
If available please advise of cost and condition.
Thx, Bob
PS...I think you are correct...they are all Lesbians...what a shame :)
