Hi... Today I mounted two crankcase breathers (as in the picture).
Also changed the turbo inlet from stock to a billet without the oil intake (attach a pic of that to)
I took of the IC and cleaned it yesterday. Putted it on again today. When I was going out to do a test with the car, it worked very bad...
The BLM:s is for the most time in 110-116. I can get the car over 3500 rpm cause it drown... At 3500 it starting to shake and almost shut down. The o2:s is in 850-910... I am not able to put any boost in the car either.
What the hell is wrong ? This was going to be a easy mod I thought... My thoughts go to vacum leaks... but I have double checked the hoses on the IC, and they sit where they shall.
IAC is ok, TPS is ok to. No service engine light is on.
Any suggestions ?
Daniel
Any suggestions ?
Daniel
