Intercooled88s
Moderator
- Aug 10, 2004
Ttt
i`m looking for 1 centercap and a power steering reservoir. am i in luck?
thanks
bryan collins
bryancollins1@lycos.com
Thanks for the reply Bob. Sorry I couldn't get back to you sooner, but puter crapped out(virus). I really need to get a stock piston before anything else. Car is just sitting now, and I really can't splurge on a rebuild as $$ is tight. I can't believe the **** thats been happening to me lately. If anything can go wrong it is at the moment. I just want to get this thing up and running so I can get it to the body shop.(please don't ask):frown: Let me know if you or maybe someone else on the board has a good known stock std bore piston. Again, thanks for the reply, you da man!! Later..........
KB
payment sent for block via paypal.
i need a gn centercap
i need 84 compressor and a/c hoses if they work good
GN Front and rear seats in good condition(power driver seat also) $600
GN Console with shifter and T handle $200
GN steering column with tilt/cruise $150
steering column Non tilt $90
87 GN wheels(4) in nice condition(with center caps and lug nuts) $600
Header panel(T-type header panel with hole on top filled, GM not after market) $150
Kenne Bell valve covers $100
87 GN Electric fan $50
Radiator hold down(plate on top that hold radiator and electric fan) $40
New Cam Position sensor CAP $40
Complete 86 T-type front clip $800
GN front bumper $100
K&N cone air filter with sensor in neck $20
87 GN seat belt set $100 for all 10 seat belts
T-type header panel $150
T-type header panel with hole on top filler $150
GN spoiler (GM , 3 pieces) $175
Racing seats(2) $100 (I won't ship these)
Fuel cell $60
Shifter with T handle $50
Concert sound 2 lower door panels(gray, 87 T-type) $100
Blackout headlight bezels $50 for both
blackout marker light(passenger side only) $25
ATR Ram Air box with K&N built into it(the box is made of alum) $40
Bigger the stock front sway bar $70
NEW Richmond 3.73 gears $90
BQ tranny $500
Fuel sender/fuel hanger(analog gauge) $100
ENGINE PARTS:
AC compressor(84-85 AC compressor) $40
AC compressor(86-87 AC compressor) $60
AC lines(86-87 or 84-85) $40
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(85 Turbo to intake adaptor) $40
Adaptor(Oil cooler adaptor with nut) $30
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $25
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $80
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover) $20
Block(109 Block) $250
Cam position sensor just the lower part(no cap) $30
Cam position (sensor with cap) $65
Chip(stock 86 chip) $30
Chip(stock 84 chip) $20
Coil pack(84-85) $40
Coil pack(86-87) $40
Control module(84-85) $50
Control module(86-87) $70
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
Crossover pipe(84-85 Exhaust crossover pipe) $35
Crossover pipe(86-87) $45
Dip stick and tube(86-87 dipstick and tube) $40
Dip stick and tube(84-85 dipstick and tube) $30
ECM(85-85 ECM) $40
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $40
Headers(factory Exhaust headers,both sides)$100
Heads(stock 8445 heads needing rebuild) $50 a set
Injector harness(84-85) $35
Injector harness(86-87) $40
Intake manifold(86-87 Upper intake manifold)$35
Intake manifold(84-85 GN intake) $40
Intercooler $45
Intercooler brackets both for $50
Intercooler fan $40
MAF(86-87 MAF) $90
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Motor mounts(metal, frame mounts) $35
Oil pan(Turbo oil pan) $35 each
Power steering pump(86-87) $70
Pulleys(86-87 underdrive pulleys(crank and alt)) $35
Pulley(86-87 Crank pulley with adapter) $30
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$15
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(86-87 Throttle cable) $30
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Valve covers (84-85) $30
Wire harness(84-85 engine wire harness) $100
INTERIOR:
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Concert sound 2 lower door panels(84 GN) $80
Console shifter plate(Plate on console that goes around the shifter)$25
Console (87 GN)$150
Dash pad no cracks(grey or Maroon) $100
Dash pad(Maroon dash pad, no cracks) $100
Dash plaque(87 GN) $90
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Gauge cluster(Analog) $80
Gauge cluster(Digital) $100
Light sage green seat belt guides $25 for both
Light sage green seat belt upper bolt cover, triangular shaped trim piece $20 for both
Map light $20
Radio(Stock GN radio, no EQ) $50
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hradtop car $40 for both
Seats(87 GN Front bucket seats need recovering) $150
Shifter $35(84-87 GN, needs T handle)
Steering wheel (Grey and in excellent condition(not redyed or recovered) $300
Steering wheel(good to have recovered) $40
Steering wheel(Tri shield GN horn center $40 no ring)
Steering wheel(T-type horn center $30 no ring)
Steering wheel(T horn center $30 no ring)
Surround(Gauge surround) $30
Surround(radio surround) $20
Third brake light(Grey, red Maroon, or blue Third brake light)$20 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, grey and blue
Visor(Nice blue passenger visor with lighted mirror) $20
Body Parts:
Blackout(Front windshield blackout trim(3) )$40
Blackout(rear window blackout trim(3) )$30
Blackout(Trunk Lid blackout trim piece) $35
Bumper(GN Front black bumper) $100
Bumper(GN Rear black bumper) $70
Bumper reinforcement(Alum. Front bumper reinforcement)$90
Bumper reinforcement(Alum. rear bumper reinforcement) $70
Grill (86 T-type grill) $50
Grill(85 GN grill) $60
Grill Emblem(85-87 T-type grill emblem) $15
Grill emblem(87 , says "Buick") $15
Fenders(84-87 GN fenders(GM)) $80 each
Lock set(all 3 locks with key) $60
Quarter windows with blackout trim $80 for both sides
Tail lights with blackout trim $90
T-top black trim that the t-tops rest on(sort of L or boot shaped) $50
T-top boot shaped plates that the t-tops lay on $60
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror)$20
Windshield blackout trim(3) $40
Windshield chrome trim(3) $30
Wheel wells(Turbo plastic wheel wells) $80 each
Any other blackout piece e mail me I have them all
Hood(GN hood) $95-$150
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Misc:
Antenna( black manual antenna complete with mast, base and nut)$35
Antenna base nut and spacer for Power antenna with black trim $10
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $100
Hydrobooster brakes $100
PowerMaster(complete unit) $170
PowerMaster to firewall adaptor(bracket) $30
power trunk mechinism $20
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
Tranny dip stick and tube $40
Transmission oil pan(Stock 200 4r tranny pan) $25
Valve body(BQ valve body $200)
windshield wiper assembly $15
Wheel(86-87 GN wheel) Good for a core $30 each
E mail me at Fortune628@aol.com or Bobhebert574@aol.com
My phone # is 413 563 8819 , don't leave message just try again later if I don't answer. E mail and PM are best to contact me.
I Need Dip Stick And Lock Set How Much Together For Those Parts Or Might Just Take Header Panel Alone Would You Take 180.00 Shipped For Header Panel Thanks
Bob,
I'm back from the GS Nats. You sent me an LC2 engine oil dipstick but mistakenly paired it with an LM9 tube. I PM'd you on May 12 when I received them but haven't heard from you. Do you have the correct tube so that this can be fixed?
