All prices DO NOT include shipping.
PAYPAL is preferred.
Any questions, feel free to PM or email me.
yullose001@yahoo.com
1) Reman LS1 MAF sensor (no screens) $50
2) Pass side kick panel upper trim only $15
3) Pass side kick panel complete (3-pieces) Chewed-up where Powerlogger plugs into ECM. $30
4) Factory injector harness $20
5) Factory GM used crank sensor and bracket $10
6) Pile of new misc 231 header gaskets $10
7) Good ECM with bottom removed for Powerlogger attachment. (no dust cover) $40
8) Set of 12 pushrods 8.400” $40
9) Engine harness plastic cover (upper only) $15
10) New R42TS sparkplugs (11) $12
11) Small pass side VC breather (chrome cap missing) $5
12) VC breather (used) $5
13) VC breather (used) $5
14) Used cam sensor cap (works) $15
15) New cam sensor (brand unknown) $65
16) Used Alky Control pump (older style but works fine) $50
17) Turbo heat shield (cut for THDP) $30
18) Battery hold down strap (used) $5
19) Coolant temp sensor for gage (used) $5
20) Coolant temp sensor for ECM (used) $5
21) IAC + housing (used) $20
22) Biggie oil filter adapter (used, with marks on threads from channel locks) Still useable $15
23) PCV 1-way check valve $15
24) VSS plug from back of instrument cluster $5
25) Fuel pressure gage 0-60psi 1/8” NPT (used) $15
26) Factory oil cooler adapter $20
27) Pile of TypeII coil packs and modules (used) $100
28) Stock GN driveshaft with good U-joints $50 (pickup only / no shipping)
29) New upper radiator hose $10
30) Factory water pump pulley $15
31) Factory crank pulley $30
32) Russ Merrit AC Delco plug wires for TypeII coil pack setup (used) $30
33) Throttle cable / kickdown bracket $10
34) Factory alt/ps/ac accessory bracket $30
35) Cruise control diaphragm & bracket $20
36) Belt tensioner (used) $20
37) Under dash sound deadener kick panels (driver & pass) (no juite material) $20
38) Factory linkage from column to trans $20
39) Factory vac lines (no PCV lines) $20
40) 1” spacer for Dominator carb $20
41) CV893 AC Delco PCV valve $5
42) CV893 AC Delco PCV valve $5
43) CV893 AC Delco PCV valve $5
44) Factory turbo drain line (used) $20
45) Autometer 1.5” gage mounting bracket $5
46) Autometer 1.5” gage mounting bracket $5
47) Wire support conduit for front of oil pan $5
48) Distributor/cam sensor hold down bracket $5
49) Heat shield for back of turbo $5
50) Factory 200R4 shifter detent bracket $10
51) Factory spare tire hardware (used but very nice) $10
52) Misc seatbelt guides $10
53) Remote trunk relase solenoid $15
54) AC condensor lower cushions & brackets + 1 upper cushion $5
55) Shifter plastic parts $10
56) Spring type cam button $5
57) Under hood lamp assy $5
58) Washer nozzles & hose $5
