BHJ Balancer rubbing front cover
tta1401
Finally installed the last piece of my build (balancer) and the reluctor ring is rubbing the front cover. Anybody else had this problem? No thrust play. Stocker didn't rub. Proper clearance on sensor. I've got enough room to get a small grinding bit to get the clearance needed. Anybody know the stock clearance between the two?
youll need a shim (or 2) on the crank
you may also have to shave down the bracket that holds the crank sensor
its a bhj thing...
First thing I thought after hearing it was the sensor rubbing. After inspecting it, no rub marks. Any idea where I can get shims?
Thinking back, I've had minor belt squeal. The relationship between the water pump pulley is off. I'll measure and that'll be the shim(s) I need.
