The LG8 was a modern 307 in³ 5.0 L High-Output derivative of the LV2 produced from 1983 to 1987. Performance modifications included a "hot" camshaft (in reality, the base model 455 camshaft), stiffer valve springs, heavy-duty exhaust valves, the larger vibration damper from the 350, a Y-pipe dual-outlet exhaust system, and richer secondary metering rods in the carburetor. It was offered in the Hurst/Olds version of the Oldsmobile Cutlass Calais and in the 442 version of the Oldsmobile Cutlass Salon. Output for 1983-1985 was 180 hp (134 kW) and 245 ft·lbf (318 N·m). Revisions to the engine for 1986 included roller lifters with a slightly smaller camshaft, new heads with smaller, swirl-port intake runners, floating piston pins, and larger piston dishes for lower compression. These changes increased torque to 250 ft·lbf (325 N·m) but lowered power to 170hp, while lowering the RPM at which peak horsepower and torque was achieved.
Applications:
* 1983-1984 Hurst/Olds
* 1985-1987 Oldsmobile 442
* 1985-1988 Cadillac Sedan Deville Brougham w/ VIN 9
