Now lets make things more interesting. Using a 3.0L piston we get the following:
Bore: 3.84"
Stroke: 3.40"
Head Gasket Thickness: .043", with an assumed bore of 3.90"
Head cc: 46
Piston Dish cc: 12
Deck Clearance: .06"
Static compression of: 9.29
Static compression of: 9.85 (with .018” head gasket)
Static compression of: 8.95 (with .060” head gasket)
With this option I don’t need to deck the block or mill the heads. Has anyone here actually used the 3.0L pistons? The 82-85 pistons are listed as flat tops, and the 85-88’s are listed as 12cc dish. The compression distance and pin diameter look to be the same as the 3.8L. Am I missing something that would keep me from being able to use these? A side benefit is the ability to swing the compression ratio by almost a full point with a head gasket change. Comments anyone?
