I bought a used TA 49 Turbo that needed a re-build. I am in the process of rebuilding it. I was putting it together and it seemed that there was a lot of play between the new bearings and the center housing. So I decided to do a comparison to my stock turbo. I took the stock turbo apart and measured the OD of the bearings and the ID of the hole in the center housing for a comparison. The OD of the bearings were exactly the same size, but the ID of the housing was way different. My stock Turbo measured .621 Dia and the TA 49 housing is .635 dia. This seems to be a lot of play.
What do you guys think? Is this too much play or should I go ahead and use it? If not, can I use the stock center housing instead of the one I got with the TA-49, they look like they are exactly the same.
Thanks,
Matt
Thanks,
Matt
