Originally posted by salvageV6
Power brake fuse runs the fan delay relay.
Probably the culprit.
Might want to pull the connectors off the relay (large one with two connectors on the drivers side) and test it alone and put the fuse back in.
But looking at the diagram that's the only two circuits on that fuse so I guess it's got to be the delay relay unless the connector for the brake is slightly shorting to ground causing some draw, about a million to one shot however.
Either a bad door switch or the wire itself is shorting to ground on a screw somewhere since they are grounding switches.
