Look at output voltage of the alternator. Alternators are 3 phase and most make around 100 to 130 AC volts at higher RPMs!!!!!!
If the regulator is bad or is poorly grounded, voltage can go high, and if any one of the diode trio shorts, (there are 6 of them) then an AC component superimposes itself on the normally DC output. That can fry lots of stuff!
If you know someone, or a shop, with an oscilloscope, probe the alternators output terminal and look for AC ripple on it. Its easy to see. Bad connections and grounds can also cause voltage spikes that will also fry things.
Uh, ya don't happen to have low impedance injectors in yer motor with a stock computer, do ya?
Just a few things to look at....
TIMINATOR
