Hello, the info on this board is great, just wished I would have done some reading here before I bought the car No sense crying over spilt milk now though....but if anyone is buying a GN in brooklyn, I can tell you who not to buy from (the guy has 3 more). Anyway working through some issues, and wanted to see if anyone could confirm. "spring cleaning" complete (filters, fluids, plugs, wires, etc.). I replaced the coil, because one of the towers had full resistance (1-4), the backfire under load went away and the car pulls hard @WOT with 13lbs boost. Has a miss at idle and crusing, no backfire, put it in gear while cold and it stalls. I don't have and can't afford module/coil tester so I put an inductive timing light on each wire. Here's what I see at idle - 1,3,5 appear to be firing normal, 2,4,6 are firing at least double the rate of 1-3-5 and not consistently, a definite "break" (miss ?) in the rythm. Plugs look fine, no fowling. Bad ingnition module???? Or what else might be possible, TPS is set correctly, by the way. Thanks.
