i pull 5v right off the tps gray wire, ground to block
that list is the analog AUX 1-8 in order , 1 is fuel , 2 should be saved for oil , 3-8 are named and should have values for expected sensors but you can change the names to whatever you want , just type in the name you want in the edit sensor window , then change the sensor values to what you need for the sensor you choose to run . the help section has a chapter on calculating the sensor settings
