I recently inherited an '85 GN, with stock everything. It was in running condition, but (of course) we took it down to nothing and rebuilt the engine (without performance upgrades). Complete Tune-up preformed. The vehicle was restored and is completely running.
2.5" exhaust system installed. Downpipe to 2.5" testpipe/cat to dual 2.5" Hooker Maximum Flow Mufflers.
Here's my situation.
The vehicle has a huge exhaust backfire in overdrive.
The cat is now installed but it happens with the test pipe, or the cat; no difference.
1st gear acceleration ok, deceleration ok, cruising ok, all RPMs ok
2nd gear acceleration ok, deceleration ok, cruising ok, all RPMs ok
3rd gear acceleration ok, deceleration ok, cruising ok, all RPMs ok
Overdrive acceleration ok, deceleration ok, cruising backfire, not ok at lower RPMs
As long as there is a positive acceleration, even if it is ever so slight, it's fine. Also, if there is hard deceleration, it's okay. It's the feathering at 70 MPH on flat ground to maintain that 70 MPH that causes the backfire.
For instance, Interstate 5 in the middle of CA (straight flat road), Cruise Control On.
60 MPH Backfires on Deceleration part of the feathering.
65 MPH Backfires on Deceleration part of the feathering.
70 MPH Backfires on Deceleration part of the feathering.
75 MPH Backfires on Deceleration part of the feathering.
80 MPH Slightly higher wind resistance, more throddle, less back firing.
85 MPH Slightly higher wind resistance, more throddle, less back firing.
90 MPH Enough wind resistance to require positive throddle, even if there is a slight downhill; minimum if any backfire.
95 MPH Not worth chancing an explanation with CHP.
I have seen many problems helped by the fine GN owners in this forum, and I am hoping you could help me as well.
Thank you very much.
