What clutches are you replacing? What are you using for clutches? What mods are you using on your trans? Boost valves? Vb mods? Clearances in trans?
Well I am a GM tech and I have been to those classes and they teach nothing about making one live behind our v6's. Since you have billet parts you need somebody who can work their magic on the calibration.The flare with 2-3 shift is the big problem.
As far as the rest, I don't have a clue. It was custom built by a GM tech with 200-4R training and he used almost every billet part in Bruce Toelle's product list.
Don't do my own work and put my trust in those who can.
If you're coming down for the races next week you can drop it off with Jake in Sanger. He might even be able to build it while you're at the races and pick it up on the way home.
Not a problem Phil. I didn't think you were going to race it, but if you were going to the Texas Buick Nationals you could drop it off at Jake's on Friday and might be able to pick it up on Sunday on the way back.Not going to race it in it's present condition. If the local guy that normally fixes it can't get to it soon enough for me, I'll want to talk to Jake and get his ideas on what parts to use to make this thing live longer and have them all available for him to install.
Thanks for reminding me about Jake.
While I'm not even close to a guru, I do a lot of reading.
I haven't used the additional clutch setup as I think that it uses the clutches and steels that are thin. Thin gets over heated even though there is more surface area. This is where the setup is crucial(so I have been told and read). If your direct is setup loose and you don't have the pressure at a suitable level you get toasty clutches and steels.
This forum is littered with stories of the local builder that is great but has no experience with the 2004r , so you are the guinea pig and buy at least twice. Your money, your call but I'd be looking for a proven product, not promises.
Do you have your directs dual fed?
