I just changed from a stock converter to an original Art Carr 3500 non lockup. I replaced the lockup valve with a non-lockup valve, removed the check ball & O-ring, and used new fluid and filter. When compared to the stock converter under race conditions, the new 3500 converter seems to be running 200 to 300 RPM higher than the stock converter when compared to MPH throughout the entire run. I would expect the RPM's to be slightly higher until the stall speed was reached, and then be identical to the stock converter, but this is not the case. I do not think the trans is slipping because the car was not driven between the base runs with the stock converter and the runs with the new converter. I feel this would be a remote coincidence that the trans just went bad between converter swaps. Any help would be appreciated.
